CEL #12 and #23 .. help clear them ..
I have 96 Accord with H22 swap. CEL light comes on once in a while around 5th gear @ ~50mph. I check the CEL codes and its 12 and 23 ..
CODE 12 - EGR - exhaust gas recirculation lift valve
CODE 23 - Knock sensor
.. now .. who knows how to fix these problems? does Knock sensor mean the sensor is bad or that its sensing knock? Code 12 mean the ERG lift valve is bad or that the EGR valve is sensing a problem?
the first thing i would check for code#12 is that all the vacuum lines are connected....
code 23 does not mean that the knock sensor is bad... check electrical connection first
big pic.
http://www.we-todd-did-racing....D.jpg
that should help even though the procedure is for OBDI system....
that should get you started w/ the code 12... let me know if you need to see "A" or "B"
edit:
here are the diagnostic procedure for code 23
1.
2.
again im not sure if that will help since the procedures are for OBI... good luck
Modified by SUB-0 H23 at 2:30 PM 5/26/2005
edit:
1.
2.
AccordRacing
May 26, 2005 08:14 PM
