B18b int mani and head swap
car is a 90 teg sedan. i have access to a complete B18B head and intake manifold for cheap. i read that the head and intake manifold flows better. also, the b18b cam is more aggressive. has anyone here done this already? these are low kms parts and i have to change the timing belt anyway so i thought if these parts will give me more HPs, why not ?
also, do i use the b18a timing belt and headgasket? if there's even a difference ?
is this swap worth it?
i know i have to use the obd-0 distributor and injectors.. i'm probly gonna get the head and manifold port/polished before i put em on
The head is same, but the cams will be beneficial. Regarding the intake manifold, it's not as much of an upgrade as some people would like to think. You'd be better off investing in a Blox manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcivicz »</TD></TR><TR><TD CLASS="quote">LOL! thats it. that's such a waste of cash. nevermind, i'll just use the money on other things. thanks for the replies!</TD></TR></TABLE>
Check out this website to see if you plan on building you LS and want to see several setups that make decent power. http://www.nonvtec.com
thanks! i think i'll wait until i have enough cash for a turbo set-up, which was the original plan. NA power is just not enough especially the amount of cash to power ratio
volcom40street
Oct 4, 2004 06:33 PM
