clutch wont work on the ls vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greencivic1029 »</TD></TR><TR><TD CLASS="quote">I just did a ls vtec swap (gsr head) and put it all back togethor and now the clutch wont work any sugesstions.</TD></TR></TABLE>
I suggest you fix whatever is broken.
General questions deserve general answers.
well, you may need to bleed the clutch line. but what isnt working? is the pedal just sitting on the floor? will the gears not engage?
as was stated above... be more specific.... its just like saying.. my car is broken, can you tell my why?
We need some symptoms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 »</TD></TR><TR><TD CLASS="quote">
General questions deserve general answers.</TD></TR></TABLE>
lmfao
lmfao
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laura »</TD></TR><TR><TD CLASS="quote">I don't know the answer to this... but is the LS block compatible with the GSR tranny?</TD></TR></TABLE>
Yes, the B18A/B B18C and B16 can all bolt up to a "B" tranny, sorry dont know my tranny codes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laura »</TD></TR><TR><TD CLASS="quote">I don't know the answer to this... but is the LS block compatible with the GSR tranny?</TD></TR></TABLE> <<< Only because you are a girl...forgiven
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Este_Cara »</TD></TR><TR><TD CLASS="quote"> <<< Only because you are a girl...forgiven</TD></TR></TABLE>
awww, shucks!
awww, shucks!
me buddies had the same problem last week, when he put the tranny back on the tranny was tightend but the spline wasnt all the way lined up and it scored the inside of the clutch hub so when you went to prss the clutch the clutch wouldnt dis-engage...so a quick clutch swap solved that problem....i also thought it was the hyrdrolic system, but it turned out to be the clutch
greencivic1029
May 26, 2005 07:23 AM
