Can you Mig weld Stainless steel?
Old May 25, 2005 | 10:41 PM
Luserkid's Avatar
Default Can you Mig weld Stainless steel?
Someone brought me an exhaust system that needs to be welded. Only thing is that the material is T304 stainless. (this is the kit: http://www.kteller.com/store/p...d/149 ) I was wondering if theres anyway to weld that with stainless with a mig, without gas (never had enough money to buy gas) Is it as simple as changing my wire or can it not be done at all without gas? TIA!
Old May 25, 2005 | 10:45 PM
MajorPayne's Avatar
Default Re: Can you Mig weld Stainless steel? (Luserkid)
well im not a fan of mig welding without gas at all (its messy and doesnt look good, and generally isnt as strong), so you would have to get some flux core wire...and now that i think about it im not even sure if they make flux core ss wire (someone else chime in on this), however if you get a bottle, it will just take changing the wire, although you can weld ss with regular mild steel wire, its all around better to use the right wire for the job
Old May 26, 2005 | 01:18 AM
ExploitedRacing-HR's Avatar
I never have heard of flux cored stainless wire, i think your outta luck, i guess they assumed anyone working with stainless would have enough cash to buy a gas setup! But seriously... you would need to use gas.. or just have someone locally weld it for you.
Old May 26, 2005 | 03:25 PM
beepy's Avatar
Default Re: (ExploitedRacing)
I have used flux-core wire to weld stainless before. It actually works out fine, and mysteriously is still rust-resistant. Don't ask me why.
Old May 26, 2005 | 03:42 PM
dustin's Avatar
You can just weld it with regular mild steel wire (flux core). It won't look pretty, but I don't think you are expecting pretty...
Old May 27, 2005 | 05:49 AM
david@didrace.com's Avatar
Default Re: Can you Mig weld Stainless steel? (dustin)
I'd be pissed if I brought my car in somewhere for a stainless exhaust install and they used mild steel wire to mig it up, not to mention flux-cored mild steel wire.
Either fork over the whole $80 for a tank of gas or send your customer somewhere else. Don't dick them over to make a few bucks.
To mig stainless you'd need Tri-Mix gas and filler wire that is graded higher than the material you're working with (if welding 304 use at least 308 wire).
Old May 27, 2005 | 07:40 AM
Flashmn's Avatar
Default Re: Can you Mig weld Stainless steel? (backpurge)
I used basic wire and argon to weld stainless, no problemos...
You could even arc weld stainless.
Old May 27, 2005 | 11:53 AM
CRXDrew's Avatar
Basically.... If this is for a friend who just needs the **** slapped together... u can weld it w/ fluxcore.
If its for a paying customer... do it right.
Old May 27, 2005 | 04:29 PM
Luserkid's Avatar
Default Re: (CRXDrew)
Its a friend of a friend and he said if i cant do it his just going to go to any muffler shop. So i thought i might be able to do it and its mixed reviews here. Im going to go to a welding supply shop by my house and see what there prices are for gas and the right wire and see whats up.
Thanks for the insite
downest
Welding / Fabrication
Oct 7, 2009 08:02 PM
Bjorn
Apr 14, 2009 08:26 AM
twilightprotege
May 22, 2006 04:52 PM
turbotime
Apr 15, 2006 11:43 AM
Greaser
Mar 17, 2003 11:09 AM
