fitting 98 mugne abs lip to my 96 front end...will it work
Old May 25, 2005 | 07:48 PM
tankdogg08's Avatar
Default fitting 98 mugen abs lip to my 96 front end...will it work
i found one for kind of cheap.....just wondering if anyone has heated one up and formed it to fit...does it look decent...will it even work?.....is it worth it
Old May 25, 2005 | 08:35 PM
1hOt95GsR's Avatar
Default Re: fitting 98 mugen abs lip to my 96 front end...will it work (tankdogg08)
i doubt it would bolt right up smoothly but not 100% sure. you could probably make it fit but not worth it imo...probably wouldn't look too clean.
Old May 26, 2005 | 02:45 PM
revautousa's Avatar
If you are just looking to save money, do it, you can heat it up and mold the plastic. If you want it fit fit and look 100% perfect. dont do it.
Old May 26, 2005 | 02:57 PM
Deluzional's Avatar
Default Re: fitting 98 mugen abs lip to my 96 front end...will it work (DA JeLLie)
If it was polyurethane you would be able to heat it up...but not abs plastic, itll just snap
dtran
Paint and Body
Sep 14, 2010 06:47 PM
216.226.142.95:27016
May 6, 2009 11:52 AM
NickW
Sep 30, 2006 02:58 PM
4doorturbo
Dec 8, 2004 02:49 AM
SupaFly_Honda
May 15, 2003 06:05 AM
