knock sensor wire! shielded?
Old May 25, 2005 | 06:27 PM
CaptivaBlue's Avatar
Default knock sensor wire! shielded?
Somewhere I got the notion that KS wires have to be shielded so they don't pick up interference. I am putting in an engine this weekend and need to know. I found some at a store and got it, it is two wires in a jacket with some metal foil looking stuff to shield, one wire to power and one to ground (to the IM?). Or can I just use good ol' cheapy 18 gauge?
Old May 25, 2005 | 10:40 PM
mtber's Avatar
Default Re: knock sensor wire! shielded? (CaptivaBlue)
The factory map sensor is a joke.
Old May 26, 2005 | 01:59 AM
Default Re: knock sensor wire! shielded? (mtber)
knock sensor, not MAP sensor
Old May 26, 2005 | 08:14 AM
dwayne.eaddy's Avatar
No it is not shielded. Only shielded wires are ckp,tdc,cyl and 02 sensors.
Old May 26, 2005 | 08:29 AM
98EJ's Avatar
Default Re: knock sensor wire! shielded? (dwayne.eaddy)
yes the knock sensor is shielded! the inner wire goes from the ks to the ecu, the outer wire goes to a ground.
Old May 26, 2005 | 09:08 AM
mmuller's Avatar
Mad Scientist
Default Re: knock sensor wire! shielded? (98EJ)
i woiuld shield as much as i can....it never hurts and it can only help..
Old May 26, 2005 | 10:01 AM
Default Re: knock sensor wire! shielded? (mmuller)
Should the ground run the full length of the power? Where can I ground it? Anywhere? On the intake mani? Ground both ends?
Old May 26, 2005 | 10:09 AM
98EJ's Avatar
yes, only one end of the wire needs to be grounded. the im will work fine for a ground point.
Old May 26, 2005 | 12:00 PM
EE_Chris's Avatar
Exactly - only one end needs to be grounded and that should be at the ECU end. Do not ground both ends.
Old May 29, 2005 | 08:51 AM
Default Re: knock sensor wire! shielded? (EE_Chris)
I was hooking up my knock sensor wiring that has a large jacket with two smaller covered wires, one uncovered wire, and some foil type stuff. The guy whose garage we are using said that I should use one wire to power the KS and the uncovered wire to ground with, because that touches the foil which allegedly is what shields the wire. Is this correct, use the uncovered wire to ground with?
Old May 29, 2005 | 04:30 PM
Wes V's Avatar
The guy at the shop is correct. As long as the unshielded wire contacts the foil, you are fine. If in doubt, use an ohm meter to check that they conduct together.
When I wired my GSR, I used shielded wire for the KS, but all the aftermarket conversions don't bother. So, I'd question if it's really required. It is a shielded wire in the original (OBD1) loom.
And, I grounded the line at the ECU.
Wes
rockseeb
Jun 28, 2017 11:44 AM
juanchoenuncrx
Aug 24, 2007 04:48 AM
nub_pwn
Nov 18, 2006 11:48 PM
SleeprCivic
Jul 3, 2003 09:54 AM
