Will a GSR OEM crank pulley fit to b18b?
Here are some lengths I have on file that you can reference to go to the store with:
GS-R Alternator Belt = 4PK785 (4PK310, that's 31.0" converted from 785mm)
CR-V PS Belt = 4PK900 (4PK355)....all B-series 4-rib crank pulleys should use the same diameter PS pump drive so all of the belt lengths are the same. Give it a try.
ITR AC Belt = 4PK790 (4PK310, but I found 305 works better for me)....since the ITR AC drive is smaller in diameter, go up another half inch to 310 or 315.
You'll probably find that the engine revs a little more easily with the GS-R crank pulley, and even more so if you had an ITR crank pulley.
TeamTooQuick
Sep 11, 2003 09:52 PM
