min/max compression numbers for an LS
Old May 25, 2005 | 01:08 PM
redDAinteg's Avatar
Default min/max compression numbers for an LS
can someone just give me a quick verification of the min/max for an LS motors compression numbers. thanks.
Old May 25, 2005 | 01:39 PM
StolenTeg's Avatar
Default Re: min/max compression numbers for an LS (redDAinteg)
190
Old May 25, 2005 | 02:10 PM
redDAinteg's Avatar
Default Re: min/max compression numbers for an LS (StolenTeg)
so thats the max ? whats the min ?
Old May 25, 2005 | 03:05 PM
DAguyLS's Avatar
you could be smart and search for it
Old May 25, 2005 | 03:17 PM
StolenTeg's Avatar
Default Re: (DAguyLS)
Why does it matter if it the max or min, as long as it all the same. 190 is what you should look for in an normal LS
Old May 25, 2005 | 03:22 PM
riceball777's Avatar
as long as the numbers are the same and not more than = or - 10-15
my old b16 had only 160 psi on all 4 cilenders
i think a ls can range from i think 120 -190psi
Old May 25, 2005 | 04:31 PM
redDAinteg's Avatar
Default Re: min/max compression numbers for an LS (riceball777)
i got a compression of 150 150 140 135
B18PoweredCivic
Nov 12, 2004 03:49 PM
vaporboy12
May 19, 2004 10:00 PM
PrOjEcTpImPcIvIc
Mar 7, 2004 12:00 PM
integranator
Apr 8, 2003 04:14 AM
