who makes the Hondata/Password JDM-style IM gasket that is SOLID ??
i need an intake manifold gasket similar to the Hondata and Password JDM ones. somebody makes one that is solid, as opposed to hollowed out as the two i mentioned.
not sure if i'm making sense. the reason is because my head and IM are ported to the point where i can not cut a Hondata gasket because i cut through the "webbing".
hopefully this makes sense and someone can help. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">http://www.outlawengineering.com/index.html</TD></TR></TABLE>
my mistake. Hondata gaskets are not webbed. BUT! there is not enought "meat" for me to cut my
square ports into. if i do, i get very close to, if not all the way to cutting through to the
edge. there is maybe 1/4" of plastic between the edge of the gasket and the outer-most edge
of the port hole. is this making sense? i'll try to post a pic tonight of the old gasket. i have
no idea what brand it is. i only know that is was bought from someone on H-T.
i need a gasket that is larger around the outside.
i checked out outlawengineering, but they have no picture of the gasket for my application
(gs-r head), only a generic pic.
