Cold air intake for turbo inlet
Old May 25, 2005 | 11:31 AM
90wagon4wd's Avatar
Default Cold air intake for turbo inlet
I made a CAI for my car. Filter is in the fender well. Before it was wedged right in between the mani and rad, freaking hot.
I routed the PCV and valve cover breather to a slash cut bung on the CAI. I don't smell blow-by fumes under boost anymore. It also sounds pretty good. The turbo spooling is alot louder now.
A little vid. I like the way it sounds.
http://www.we-todd-did-racing....DE%3D
Old May 25, 2005 | 11:39 AM
Finland's Avatar
Nice idea, and sweet little car too!
EJ1 wilcox's Avatar
Default Re: Cold air intake for turbo inlet (90wagon4wd)
How much work was it? I would like to do something like this some time...
It would be nice to not smell after driving my car.
I like the wagon too!
Old May 25, 2005 | 11:59 AM
Thurman Merman's Avatar
Default Re: Cold air intake for turbo inlet (EJ1 wilcox)
any downfalls... pros/cons with spool up when running a longer intake inlet?
Old May 25, 2005 | 12:03 PM
Muckman's Avatar
Moderator in Chief
I hope your motor doesnt twist too much or it will break that pipe right off.
Old May 25, 2005 | 12:23 PM
90wagon4wd's Avatar
Default Re: (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">Nice idea, and sweet little car too!</TD></TR></TABLE>
I have to admit, I stole the idea from Dturbocivic.
https://honda-tech.com/zerothread?id=638137
I wanted to make an intake mostly to have a place to run the PCV to a constant vacuum.
The POS is fun <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
How much work was it? </TD></TR></TABLE> Drilling the hole was the hardest part. I ending up renting a badass drill and bimetal hole saw bit, after getting nowehere with my $29.99 sissy drill. Took 2 hours including trip to tool rental.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman &raquo;</TD></TR><TR><TD CLASS="quote">any downfalls... pros/cons with spool up when running a longer intake inlet?</TD></TR></TABLE>Spool seems better, but I am using a bigger air filter now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I hope your motor doesnt twist too much or it will break that pipe right off. </TD></TR></TABLE>
Thanks for your concern Somehow I think the rubber home depot coupler will stretch or tear before the steel pipe will bend. Been beating it hard for a month, no issues.
Old May 25, 2005 | 12:38 PM
mrbsponge's Avatar
i have wanted to do this but i dont have any inner fenderwell liner and was worried about water, and even worse..............
when i go to the track and do a burnout, im sure my engine will re ingest some of that smokey air, and im sure it isnt good for my motor, so i guess i should get an fender liner!
Old May 25, 2005 | 07:27 PM
dunkd's Avatar
i think you got your EGT and o2 placement mixed up
Vagitarian
May 18, 2013 09:16 AM
Smooth-GSR
May 25, 2004 08:58 AM
xenocron
Dec 18, 2003 10:48 AM
killa_lude
Oct 13, 2003 11:52 AM
Stock@$$GSR
Mar 4, 2002 11:17 AM
