91 Harness in 88
Old May 25, 2005 | 11:17 AM
BlingBlingCivic's Avatar
Default 91 Harness in 88
I chopped up the harness in my 88 civic for a MPFI swap. Now i'm going to sell the car because I bought a 91 Hatch.
The harness was already out of the 91 so I decided to just put that in the 88 so i could use the MPFI harness in the 91.
It appears there are some wiring differenced between the years though, Does anyone know if the 91 harness can be used in the 88 with switching some pins?
Which pins?
thanks
Old May 25, 2005 | 12:10 PM
Rywire's Avatar
Default Re: 91 Harness in 88 (BlingBlingCivic)
What models are the cars... si, dx, and hf are all different in the harnesses, and in most cases the 88 is the odball. Please be more specific
Old May 25, 2005 | 12:59 PM
Default Re: 91 Harness in 88 (droppedcrxsi)
sorry, i posted that quick before work
the 88 is a DX and the 91 is an STD
Old May 25, 2005 | 02:30 PM
with some searching (i know i should have done this before) i found that a big difference is the eacv 12v wire is moved to another harness. I think i can fix that easy enough.
Is there anything different with the top dead center sensor?
hndakd
Apr 10, 2012 07:38 AM
jackmode9316
Sep 11, 2007 12:27 PM
gnar kill
Mar 12, 2006 06:52 AM
KhialD
Jun 1, 2003 03:07 PM
