What's the best resin release to use on a vertical trunk liner surface?
That's basically it in a nutshell.
This is on a vertical and very contoured side panel inside a trunk, so I can't very easily lay plastic sheeting down in there before I lay down the fiberglass.
What do you recommend?
I've tried duct tape in the past but the problem with it is that when the resin is curing and heats up, it melts the adhesive on the duct tape into the carpet and then is almost impossible to get out of the carpet.
How do you get around this problem?
LuderCriS
Aug 27, 2002 07:29 PM
