Does oil pressure sender sense before or after oil filter?
Old May 25, 2005 | 09:37 AM
Jason C SBB's Avatar
Default Does oil pressure sender sense before or after oil filter?
In the lubrication circuit of the D and B series motors, is the oil pressure sender location between the oil pump and filter, or between the filter and the rest of the motor?
TIA
Old May 25, 2005 | 10:11 AM
Default Re: Does oil pressure sender sense before or after oil filter? (Jason C SBB)
Oh, and you guys who add aftermarket oil pressure gauges, do you just tee in the stock oil pressure switchlocation?
Old May 25, 2005 | 10:59 AM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason C SBB &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and you guys who add aftermarket oil pressure gauges, do you just tee in the stock oil pressure switchlocation?</TD></TR></TABLE>
if you're talking about the plug on the back of the block, just replace it with the gauges sending unit/feed line. all it does is trigger the dummy light which you dont need with a gauge
Old May 26, 2005 | 02:15 PM
So does oil see that location before or after passing through the oil filter?
Old May 26, 2005 | 02:57 PM
Chiovnidca's Avatar
Default Re: (Jason C SBB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason C SBB &raquo;</TD></TR><TR><TD CLASS="quote">So does oil see that location before or after passing through the oil filter?</TD></TR></TABLE>
After.
9hatch6
17
Apr 24, 2005 04:08 PM
hondapwr
Mar 11, 2004 02:43 PM
dseriessol
Feb 29, 2004 03:31 PM
strils
Feb 25, 2004 05:06 AM
Si Erik
26
Sep 8, 2003 06:02 AM
