How many different height settings do Koni Yellow provide? (more)
Which of the settings provides ride height eqivalent to stock?
From what I've read in other posts, the Integra has more wheel-well gap in front than in back, and when using springs that lower equally all around, such as Eibach Pro-Kit or Comptech, the difference becomes more apparent. Will using a lower setting on Koni Yellows for the front make the car appear more level, or would this make the front much lower?
Thanks for your help,
Phil
Phil
front would be much lower.. don't worry about the front being higher than the back, its not very noticable. actually, the only springs that will highlight this would be the pro-kit, because the springs itself cause an uneven drop. H&R's and other springs should be just fine.
Alex
Alex
Manolo
Suspension & Brakes
13
Apr 18, 2006 08:24 PM
