Expo seatbelt question
Old May 25, 2005 | 04:45 AM
Aquafina's Avatar
Default Expo seatbelt question
Is twisting of the seatbelt (one or two twist where you click it in) allowed to keep the belt tight? I do this at local autocrosses and it helps me a lot since my paper flat seats suck.
Old May 25, 2005 | 06:04 AM
DC2fanboy's Avatar
Default Re: Expo seatbelt question (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Is twisting of the seatbelt (one or two twist where you click it in) allowed to keep the belt tight? I do this at local autocrosses and it helps me a lot since my paper flat seats suck.</TD></TR></TABLE>
I did it at last expo and had no problems...
Old May 25, 2005 | 08:58 AM
lanceh's Avatar
25 Year Member
as long as your seatbelt is in good visual condition and you're wearing it i don't care what you do.
if you do this often i'd be concerned about premature wear. it's not really necessary to do this but if it makes you happy. by all means
Old May 25, 2005 | 09:28 AM
Chris F's Avatar
Default Re: (lanceh)
For autocross, the twisty method is pretty decent. Gives your top-half some mobility.
I won one of these at a NASA event (thanks Frisby Race Tire) and it works better than the twist method.
http://www.frisbyracetire.com/CG_Lock.htm
I'd say you'd be better off using the inertia lock method, to lean the seat back, snap the shoulder belt to lock it, then sit forward. But whatever floats your boat.
-Chris
bks84
Mar 4, 2009 05:03 PM
LvN
Apr 19, 2005 01:19 PM
baonest
Feb 24, 2004 10:42 PM
MrIllegalX
16
Oct 26, 2003 12:20 PM
Mike D
27
Jun 17, 2003 10:39 AM
