SKUNK2 Lowering Springs
Old May 24, 2005 | 09:45 PM
aleks77's Avatar
Default SKUNK2 Lowering Springs
Hey guys came across these on ebay, just wondering if these are any good? I really like the 2" drop, i know ebay stuff is usually junk but these look like real skunk2 lowerin springs, any input? thanks!
http://cgi.ebay.com/ebaymotors...&rd=1
Old May 25, 2005 | 12:13 AM
2+2=5's Avatar
Default Re: SKUNK2 Lowering Springs (aleks77)
they look real but skunk2's suspension are known to be junk.
spend it on H&R, EIbach, tein instead
Old May 25, 2005 | 12:18 AM
Confuc1ous's Avatar
I wouldnt put money into Skunk2, they arent even manufactured by Skunk2, they are an outside company that labels them post-manufacture, i suggest you aim toward something by Neuspeed, H&R, or Eibach. Tein springs are decent but their lower levels of springs, their cheaper sets are made the same way the skunk2's are, outside of their plant.
Old May 25, 2005 | 02:16 AM
iand415's Avatar
Default Re: (Confuc1ous)
i have skunk2 lowering springs in my 6th gen and they're pretty bouncy. if i were u, i would take everyones advice and spend your money on something better the only thing i like about my skunk2's is the stance, its lowered 2.5" all around.
Old May 25, 2005 | 03:49 PM
sportyaccordy's Avatar
Default Re: (iand415)
MAAAAAAAD stiff, and not even that quality. Go with Sprints, Tanabes or Teins if you want stock struts to last.
Old May 25, 2005 | 04:15 PM
Confuc1ous's Avatar
Default Re: (sportyaccordy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportyaccordy &raquo;</TD></TR><TR><TD CLASS="quote">MAAAAAAAD stiff, and not even that quality. Go with Sprints, Tanabes or Teins if you want stock struts to last.</TD></TR></TABLE>
I dont know about sprints, ive had problems with them in the past, but tanabe's should be good, ive never heard any negative press about those. Tein, like i said, if you go with the lower quality joints, you will get what you pay for.
Old May 25, 2005 | 05:06 PM
cottonfamily05's Avatar
I am looking to keep my stock struts so what is going to be the best call for a 1.5 to 2.0 inch drop? If needed would go 2.5 !!
Old May 30, 2005 | 01:57 PM
Confuc1ous's Avatar
man, stock struts, wow, the best you can go with them, if you want them to last a little longer than a year or so before blowing out, i suggest the sof sports, remember, the lesser the drop, the longer the struts will last. If you are looking for 1.5 to 2.0 then your struts are doomed homey. I suggest you just save some dollars for a full coil-over system.
Old May 30, 2005 | 09:07 PM
96vteccd5's Avatar
I am running H&r sports springs and agx shcoks. Love them to death but I want to change up the suspension and be a little different so I wil probably get these.
Taken from H&R website
H&R CUP kit
2.0front 1.75rear
"H&R Cup Kits are an ideal solution for those that want aggressive looks and impressive handling at an affordable price. H&R's Cup Kits are specially engineered from the ground up with custom-designed springs and shocks that are developed together to work in perfect harmony.
Unlike competitors spring and shock kits, H&R Cup Kits are not merely a 'matched' spring and shock package, but rather a specially engineered 'solution' with springs and shocks being engineered individually in every application. This takes the guess work out of your spring and shock selection, and provides you with an application specific, precisely calibrated spring and shock set designed to deliver improved handling, uncompromised ride comfort and sleek styling in one precision engineered package."
Old May 31, 2005 | 02:47 AM
Confuc1ous's Avatar
Don't believe them when they say, 'uncompromised ride confort', that **** is not true.
Old May 31, 2005 | 01:06 PM
BoostedH23Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iand415 &raquo;</TD></TR><TR><TD CLASS="quote"> the only thing i like about my skunk2's is the stance, its lowered 2.5" all around.</TD></TR></TABLE>
I have the Skunk 2 which are I believe are made by Eibach. As stated above I love the stance, but with any car when you lower it you are operating outside the factory struts capacity. Thus reducing the life of the strut. If you are going to lower your car do it right and put aftermarket struts on the car too.
Trust me you won't be sorry. I used stock struts with coilovers and springs and when I finally deceided to use aftermarket struts there was a world of difference. I have the Skunk 2 2.5 drop and Tokiko Illumina's and the car handles great. When I used the setting closest to the factory it was WAY too bouncy. Stiffen it up and it's a totally different car.
Old May 31, 2005 | 02:04 PM
96vteccd5's Avatar
I could careless about a comfortable ride. I enjoy how the ride is on my agx and h&r sports. I plan on going stiffer 3f/6r. right now I am 2f/5r.
Old Jun 18, 2005 | 04:49 PM
DynastyRacer22's Avatar
Default Re: (96vteccd5)
eibach springs sucks..it doesnt really lower your car much and its good for a while later on your back end is lower then the front unless u got sum 17s+ size rims
Old Jun 18, 2005 | 07:02 PM
Confuc1ous's Avatar
Default Re: (DynastyRacer22)
I have to agree, the eibachs ive used have done exactly that, the front doesnt even look likes its dropped whatsoever given some time. They are excellent at first but then shitty later on.
blackccoupe
Suspension & Brakes
Feb 26, 2011 04:15 PM
evosix
Suspension & Brakes
Sep 10, 2010 11:08 AM
jdmcivic33
Suspension & Brakes
Nov 22, 2009 12:03 PM
93civiccoupe
Suspension & Brakes
Apr 7, 2007 02:37 PM
