91 b16 CRX *First Photoshoot*
My work in progress, 91 crx. B16 swapped, skunk 2 intake mani, bbk 70mm throttle body, msd sci L, blaster coil, dc 4 to 1 header to thermal 2 1/2 inch header back. tein springs on kyb agx. suspension techniques sway bars, neuspeed strut and tie bars ,L-con traction bars ,hasport mounts and linkage,eurethane bushings all over the place
and raxle axles, brembo rotars, green stuff pads. skunk 2 stage 1 cams and cam gears.
Buddy's Z28 on black wheels (he wishes it was a honda)
Last Two are my favorites
pics taken by sedracer
Modified by slow91crx at 5:49 AM 6/1/2005
bottom doesn't flow. either paint the front and rear bumpers with trim paint and line it up with the sides or match paint the side rocker panels.. you know.... how it was painted when it rolled off of the honda dealership floors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz »</TD></TR><TR><TD CLASS="quote">bottom doesn't flow. either paint the front and rear bumpers with trim paint and line it up with the sides. you know.... how it was painted when it rolled off of the honda dealership floors.</TD></TR></TABLE>
bottoms are in the process of being painted. everything is gonna be painted back to stock.
From: I USE E-MAIL ADDRESSES THAT DONT BELONG TO ME AND GET MY STUFF DELETED I USE E-MAIL ADDRESSES THAT D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">i think the car will look alot better with the bumpers and side moldings painted back to stock black. and i need to put my side markers on.
Agree with you on that.
</TD></TR></TABLE>Agree with you on that.
Smells like Tuna
are those c8's or c10's i can't tell
i have gunmetal c10's polished lip on my red crx
anything in that family is NICE on a crx
they are C8's . i am considering some smaller wheels actually, maybe some 14 inch sub zero's with a red lip.
and they are tein springs on the car. i dont like them because they make the car et too high. another reason the car is so high is because the tires are 2125/50/16's. i think if i go with a 215/40/16 it will set alot lower can keep those wheels and springs. if not then i am gettin ground controll coil overs
bottoms are in the process of being painted. everything is gonna be painted back to stock.</TD></TR></TABLE>
x1000000000
x1000000000
i might keep the headlights and just put a stock lens over the black projector housing. i just put the side markers on tonight and they look pretty good
my advan sticker had to move down about an inch to look right with the marker. ill post some pics after i get the trim painted.
