WTK: Cable to hydraulic clutch conversion
Old May 24, 2005 | 08:06 PM
SteyrTMP's Avatar
Default WTK: Cable to hydraulic clutch conversion
Has anyone ever converted over from cable to hydro? I am going to put a 1998 Civic D15 tranny in a 1990 CRX D15. The Civic tranny is hydraulic, where as the CRX is cable. What would be the easiest route? Cable to hydraulic, or hydraulic to cable, and either way, what do I need?
Nate
SteyrTMP
Modified by SteyrTMP at 9:31 PM 5/24/2005
Old May 24, 2005 | 08:27 PM
FalkenSiR's Avatar
Default Re: WTK: Cable to hydraulic clutch conversion (SteyrTMP)
D15 y00 mean??
You may want to look into hasport's kit... but I only think is for B series... might want to search, im not sure.
Go here, it's not that different from D series. https://honda-tech.com/zerothread?id=1206992
If you want my opinion, in a D series, it's not worth it.
Old May 24, 2005 | 08:30 PM
SteyrTMP's Avatar
Default Re: WTK: Cable to hydraulic clutch conversion (fast88std)
Yeah, D15... Still thinking of the B18 I am working on. D15... pissant little thing.
Nate
Old May 25, 2005 | 11:17 PM
SteyrTMP's Avatar
What I need to know, and I know **** about transmissions, can't I just swap forks? What is the big difference between the two? I am not going to get the conversion kit, so if I cannot swap forks, I am going to have to just remove the good gear box and drop it in the old cable bell housing.
Nate
streetsold6teeny8
May 13, 2010 04:17 PM
mikester1222
Mar 5, 2008 06:06 AM
hondaguyexsi
Sep 13, 2005 08:09 PM
performula
Mar 17, 2003 07:16 PM
MIDNIGHT
Feb 18, 2002 04:48 PM
