turbo question on gsr
im running a 95 gsr and im using
turbonetics turbo
310 injectors
thinking of tial 35mm wastegate
bosch fuel pump
my question to you guys is should i change the head gasket and if so to what?
im not changing piston right now just want to run low booost and if so will i be able to rev the car to8000+ rpms
last what chip should i use to get these hi rpms about 8500 or so
i do have 2 .1/4trr exhaust, type r cams, type r fly wheel, type r tranny with act 6 puck clutch
turbonetics turbo
310 injectors
bosch fuel pump
