can i put a new disk in a used CM clutch hub?
Old May 24, 2005 | 07:18 PM
KillaB-'s Avatar
Default can i put a new disk in a used CM clutch hub?
i have a six puck clutch masters clutch and the disk has seen its last days. can i replace it with a new street disc from a different manufacturer other than CM or should i buy a whole new clutch? is the hub reusabke with a new CM disk or not? thanks alot
Old May 25, 2005 | 06:29 AM
clutchmasters's Avatar
Default Re: can i put a new disk in a used CM clutch hub? (KillaB-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaB- &raquo;</TD></TR><TR><TD CLASS="quote">i have a six puck clutch masters clutch and the disk has seen its last days. can i replace it with a new street disc from a different manufacturer other than CM or should i buy a whole new clutch? is the hub reusabke with a new CM disk or not? thanks alot</TD></TR></TABLE>
Honestly, it is a gamble any time you mix and match parts for a clutch kit. Our kits are balanced kits which means that every single kit is tested and matched with its own disc, this ensures proper engagement and disengagement. If you do not want to purchase a new kit I suggest that you send us your old kit to be remanufactured where we exchange out all the worn parts and replace with new. If you have any questions about that option you can give us a call at (909)877-6800. Thanks
Old May 25, 2005 | 07:20 AM
RI_TM's Avatar
Default Re: can i put a new disk in a used CM clutch hub? (clutchmasters)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutchmasters &raquo;</TD></TR><TR><TD CLASS="quote">
Honestly, it is a gamble any time you mix and match parts for a clutch kit. Our kits are balanced kits which means that every single kit is tested and matched with its own disc, this ensures proper engagement and disengagement. If you do not want to purchase a new kit I suggest that you send us your old kit to be remanufactured where we exchange out all the worn parts and replace with new. If you have any questions about that option you can give us a call at (909)877-6800. Thanks</TD></TR></TABLE>
Sorry if i'm thread jacking....
But how much would that cost total?
Old May 25, 2005 | 10:17 AM
Default Re: can i put a new disk in a used CM clutch hub? (RI_TM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RI_TM &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if i'm thread jacking....
But how much would that cost total?</TD></TR></TABLE>
It all depends, just new disc linings to a full rebuild and resurfacing.. We would need the unit sent in so we could give you an estimate.
Old May 25, 2005 | 11:53 AM
RI_TM's Avatar
A full rebuild....It's a clutchmasters stage 5 (6puck)
Old May 25, 2005 | 12:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RI_TM &raquo;</TD></TR><TR><TD CLASS="quote">A full rebuild....It's a clutchmasters stage 5 (6puck)</TD></TR></TABLE>
Again, tough to say without seeing the clutch, but basically you would be looking at around $250.
Old May 25, 2005 | 06:19 PM
KillaB-'s Avatar
thanks alot im going to go with a new clutch, i have on more question though, would i feel more pedal travel and effort than a 6 puck clutch with a full disc street clutch?
Old May 26, 2005 | 07:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaB- &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot im going to go with a new clutch, i have on more question though, would i feel more pedal travel and effort than a 6 puck clutch with a full disc street clutch?</TD></TR></TABLE>
A puck disc clutch will have a little more pedal effort than the street style clutch, both should have about the same amount of travel.
integra-modder
Dec 18, 2008 07:47 AM
Propulsion
Mar 6, 2006 02:08 PM
qquaternion
10
Nov 20, 2003 11:16 AM
D16Z6racing
Nov 8, 2002 03:53 AM
