H22 Clutch Install
Old May 24, 2005 | 06:15 PM
dacosta's Avatar
Default H22 Clutch Install
With regards to installing the clutch for an H22, I know I need a clutch alignment tool to properly install the clutch. Now, I have a clutch alignment tool for a B Series and was wondering if the tool itself is the same between the B and H Series. Please advise.
TIA...Darwin
Old May 24, 2005 | 07:45 PM
K-Spec's Avatar
Default Re: H22 Clutch Install (dacosta)
if you get a clutch kit, the tool will most likely be included...atleast it did with my exeddy kit.
Old May 24, 2005 | 07:51 PM
Shakes's Avatar
space cadet
Default Re: H22 Clutch Install (khalal538)
not always.
the clutch allignment tool will not be the same. the spline length,non-spline length and number of splines will all be different. you will need an H series tool. ask if it comes with one. if not they usually run anywhere from $1 - $10 at an auto store or the dealership.
Old May 24, 2005 | 08:14 PM
dacosta's Avatar
Default Re: H22 Clutch Install (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">if you get a clutch kit, the tool will most likely be included...atleast it did with my exeddy kit.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">not always.
the clutch allignment tool will not be the same. the spline length,non-spline length and number of splines will all be different. you will need an H series tool. ask if it comes with one. if not they usually run anywhere from $1 - $10 at an auto store or the dealership.</TD></TR></TABLE>
Unfortunately mine did not come with the tool.
Thanks for the info guys
bb_one
Feb 11, 2009 08:16 AM
fridaytech
Sep 26, 2007 02:05 PM
joeys_corp
15
Aug 11, 2005 03:26 PM
choady
10
Nov 5, 2004 09:41 AM
hatch_22si
Feb 9, 2004 08:45 AM
