crx rota wheels and wheel spacers?
Old May 24, 2005 | 05:27 PM
xDicktonesx's Avatar
Default crx rota wheels and wheel spacers?
anyone use rota wheels with wheel spacers for a little wider track? if so, how big can you go before you rub the fender?
Old May 24, 2005 | 07:09 PM
bc_ef8's Avatar
I'm running 40 offset 15" GT3 with an H&R 5 mm spacer to clear my brakes. I get some rubbing if I don't have negative camber. Right now I'm at -2.3 up front and no rubbing. My suspension is pretty stiff as well. Zeal coilovers with 12k and 10k springs.
Old May 25, 2005 | 09:25 AM
Default Re: (bc_ef8)
awesome. thanks
anyone else?
Old May 25, 2005 | 09:31 AM
Crx Jimmy's Avatar
Default Re: crx rota wheels and wheel spacers? (CRXofPain)
just buy them in the offset you want and there is no need for spacers if you want it 5mm more than a 40 ofset buy a 35 offset wheel
Old May 25, 2005 | 10:41 AM
Sequoyah's Avatar
Default Re: crx rota wheels and wheel spacers? (Crx Jimmy)
I have some subzeros (15") w/ a 205/50 tire (ziex-ze 512) tire that are on my 00' EX and tried to put them on my 91' Si. Where the rim mounts up, on the backside of it were some "tabs" sticking out that are a part of the rim that scraped on my calipers. The calipers are a lot closer to the inside diameter of the rotor on my CRX and that created that problem.
Are wheel spacers the only solution to this problem? Anyone else have this happen? Other than that rubbing they seemed to fit fine otherwise...other than looking like a freaking 4x4.
jxhxb
Nov 17, 2009 06:51 AM
mrchris1979
Feb 3, 2008 12:05 AM
jas315a
Dec 7, 2005 03:11 PM
HamiltonRex
Oct 12, 2005 11:56 AM
HondaJon
Aug 5, 2002 11:35 AM
