OOB I to OBD II enginge swap
Old May 24, 2005 | 04:00 PM
folicor's Avatar
Default OOB I to OBD II enginge swap
Background: I own a 99 SI w/b16a2 with a JRSC. I recently bought a 93 cx hatch with a jdm b16 and hydro tranny coversion.
What I'm trying to do: swap the motor from my 99 SI to the 93 hatch and the hatch motor to the 99. Why you may ask. Because my 99 motor is freshly rebuilt, and the motor that's in the hatch has slightly (by about 15-20 points) low compression in one cylinder. The 99 will become my DD. The hatch will be my auto-x car.
Now I know I will have to have both motors pulled at the same time to swap parts from each of them. I just want to double check to see if I'm leaving anything out that I may run into.
Things to be swapped to keep the OBD **** straight: Crank angle sensor on the oil pump. Crank pullies (no PS on the hatch) with sensor rings/washers. Coil pickup w/wiring in the distributors.
Things I am unsure of: knock sensor, thermostat housing, and sensors in the tranny. Also wonder if the fuel rail will make a difference, and/or if I'll have problems with the throttle cables.
Any info is greatly appreciated, I'm sure I'll figure it out anyway, however if I'm leaving something out, I'm sure ur replies will save me a whole hell of a lot of time.
Old May 24, 2005 | 08:16 PM
folicor's Avatar
Default Re: OOB I to OBD II enginge swap (folicor)
BUMP................C'mon, I know there are like 10% of you that are Honda gods.
Old May 25, 2005 | 05:25 AM
folicor's Avatar
TTT.......A non-lame question like many others and nothing? Or is everybody smart enough to stay away from OBD II in the first place ?
Unlimited720
Mid-Atlantic (Sales)
Sep 11, 2012 05:35 AM
Unlimited720
Northeast (Sales)
Sep 10, 2012 06:41 AM
CTRwannaB
Nov 1, 2004 10:16 AM
aira
Oct 17, 2002 08:13 PM
