non vtec dc 4-1 header - need help
im about to buy a dc 4-1 header from a guy that has it on his non vtec b18b .. will this header work properly with my jdm b18c that is vtec? i need help bfore i buy it from this guyyy ..
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adaml2nv »</TD></TR><TR><TD CLASS="quote">yeah it'll fit. it doesn't matter if it's vtec or not</TD></TR></TABLE>
A header made for a B-series will fit on any B-series motor.
is your car a GSR or a LS. cause i think the Header for the GSR is slightly shorter, so you'll have to use a different cat. someone correct me if i'm wrong. i tried putting GSR header on my LS and it was a few inches short
All b-series headers are interchangable. However, the 94-99 gsrs are about 3 inches shorter down at the cat. So you are probably going to have to go to a muffler shop and have your cat or b-pipe extended a few inches. A shop should only charge you about 20-30 bucks to have it done.
