R-12 alternative... but sucks
Old May 24, 2005 | 03:14 PM
fe519's Avatar
Default R-12 alternative... but sucks
Hey everyone... as you know, its getting hotter and hotter. I'm sweating my pants off in my 85 CRX because I was low on freon(R-12). So I had time today and decided that this shop can evacuate all the r-12 so I can either go with 134 conversion or freeze12... I decided with freeze12. The mechanic took everything out and put in a little less than a can in and his gauge said it was within range... but it doesnt blow cold air! Its a little cooler (measured at 63 degrees from the vent) but I'm still sweating. What can be wrong? Could the expansion valve have anything to do with it? Thanks for helping me keep cool.
Old May 24, 2005 | 06:34 PM
Super Chicken's Avatar
Default Re: R-12 alternative... but sucks (fe519)
The vent temp should be about 45F with the air on recirculate. Your system should take at least two cans. I'd say take that Freeze12 out and put two cans of 134a in there. I just put a new compressor on my brothers car and put two cans in and it's still a little low, but blowing COLD!!!!!!
Old May 24, 2005 | 07:42 PM
slywfbpsi's Avatar
Default Re: R-12 alternative... but sucks (Super Chicken)
yeah, he should of put in more than mess than a can. anytime I have evacuated a system it has always taken more than two cans. Did he vacumme out the system as well? I have found that you have to fill it up to right around the max level for your ambient temperature (less than 5 psi from max) for it to be any close to the cold you are looking for. Case in point, I put enough freon in mine (r134a) to get to 45 psi, not suppose to go over 50 for my temperature. and I felt my wife's arm and it was COLD.
Old May 25, 2005 | 03:53 AM
StorminMatt's Avatar
If you want A/C that works, settle for nothing less than real R12. Face it, R134a and other alternatives just don't work well in an R12 system. Yes, it costs alot. But it's worth it.
Old May 25, 2005 | 01:07 PM
fe519's Avatar
Default Re: R-12 alternative... but sucks (StorminMatt)
well, its about 80 degrees outside right now... how many psi should it be on the low side? I cant seem to find any info about the correct psi.
Old May 25, 2005 | 02:03 PM
slywfbpsi's Avatar
80 degrees low side of the scale is 40. The range for 80 degrees is 40-50 psi.
ndiehm
Apr 30, 2012 10:30 AM
nycdave
Honda Fit
Aug 11, 2011 10:43 PM
eg:R
Jul 22, 2008 11:41 AM
97akwerd
Sep 14, 2005 08:06 PM
