help with my cluster swap....
Old May 24, 2005 | 01:51 PM
ZCcivicBOI's Avatar
Default help with my cluster swap....
i need help with my swap i got a 88 civic hatchback with the stock *** dx cluser with no tac. well my homie is giving me a 96 civic cluster anyone have the wiring diagram or pin layouts for them so i can wire it up i already got a electronic vss so i can wire up spedo cable but i just need the wiring... thx for any help.
Old May 24, 2005 | 02:13 PM
poundedhatchcrap's Avatar
Default Re: help with my cluster swap.... (ZCcivicboy)
I got tha diagram papers at my house boi. Jus come over and get them from me. Good luck on your swap man
Old May 24, 2005 | 02:54 PM
Crimson_Tide's Avatar
Default Re: help with my cluster swap.... (poundedhatchcrap)
can you post these up? i just swapped mine out for a '89 that had a tach and everything works except for the gas gauge and temp gauge... need to know which wires are which... thanks
-Josh
Old May 24, 2005 | 03:25 PM
Default Re: help with my cluster swap.... (Crimson_Tide)
if im not mistaken the fuel gauge is a yellow and white wire and the temp gauge is a yellow and green wire. Hope that helps. Like i said it could be wrong, just check them though. Oh btw those are the wires in back of the cluster
Modified by poundedhatchcrap at 4:47 PM 5/24/2005
Old May 24, 2005 | 05:00 PM
i checked and both of those are hooked up... i went out to try and fix it and when i was two wires touched eachother and sparked but it was only for a millisecond... anyways now my clock wont turn on and the tach, oil, cel, and seatbelt light arent working either... ahhhhhhh... do you think i fried the clock and the cluster? does anyone have the wire diagram?!!!!!!
-Josh
Old May 24, 2005 | 05:04 PM
Sounds like a fuse. Ill go and try to find that diagram
Old May 24, 2005 | 05:07 PM
i think this is the page https://honda-tech.com/zerothread?id=709958
Modified by poundedhatchcrap at 6:35 AM 5/26/2005
Old May 31, 2005 | 09:47 PM
FaceTuned's Avatar
tell me why
Kris' Workshop
Jun 6, 2019 07:19 AM
2000jdmciv
May 21, 2007 10:54 PM
BB6racer
Jun 18, 2006 10:29 AM
lancer
Jun 14, 2004 04:12 PM
