Help: Buying a WW RS full kit
Old May 24, 2005 | 01:10 PM
Dongoesby's Avatar
Default Help: Buying a WW RS full kit
Very luckily, after almost 6 months WW has been out of business, I found it. However, I need help to prevent scam. I'm buying it used and the kit is still on the car, and it is black, (match my color) the paint looks good, but there is a light scratch on the skirt, and the rear lip has melted a little by the muffler. My main concern is the front lip does not fit the car perfectly. The guy said it is because he didn't use factory tape.
The lip does not fit on the body perfectly? the corners at the top under the turn signal light are a little bit tilted upward. When I push it real hard, it does go back in. Is it what it suppose to be? I'm worryed, he is asking 450 firm, does it worth the money? please let me know, thanks.
Old May 24, 2005 | 01:15 PM
clemsoncb7's Avatar
Default Re: Help: Buying a WW RS full kit (Dongoesby)
I am interested in this too. Bump
Old May 24, 2005 | 01:27 PM
homesauce's Avatar
Default Re: Help: Buying a WW RS full kit (maxvtec7500)
The area under the turn signal is the weak link on the front of the 4th gen lip. It's only held on by sticky tape, and after time it wears out, and it begins to come down, and come away from the bumper. It does not fit perfectly, but I think you can tap a screw behind it to hold it there.
Is it true that the lip kit is discontinued??
Old May 24, 2005 | 02:45 PM
Dongoesby's Avatar
Default Re: Help: Buying a WW RS full kit (homesauce)
yes, you can come check here. http://www.wingswest.com/shop_main.asp
Old May 24, 2005 | 03:38 PM
homesauce's Avatar
It says temporarily closed?? Not shut down for good right, unless that's just a BS way to say it.
Old May 24, 2005 | 04:34 PM
Dongoesby's Avatar
Not sure, I'm disappointed too, people keep telling me it is out of business when I ask.
Some body shops told me they will come back at April, but....
Old May 24, 2005 | 04:47 PM
homesauce's Avatar
Next April??
Damn, how the hell did WW go out of business, they make some of the best body parts for cars...there must be some serious management issues or something. That's disappointing, I needed to get another WW RS too and ebay has nothing.
Old May 24, 2005 | 05:21 PM
prelude1897's Avatar
You could use some 3M heavy duty double sided tape. As a matter of fact, I have a roll of it that I'll sell you. I used some for my lip kit, and there's more than enough left, cause it doesn't take much to put your lip kit on. If you would like to buy it off me, just let me know.
Old May 24, 2005 | 07:30 PM
Dongoesby's Avatar
Default Re: Help: Buying a WW RS full kit (prelude1897)
To homesauce: No, this year. I asked them earlier this year.
To prelude1897: Does it really have enough? How much you are letting it go. Anyways, I might get some from my friends, or I will buy them.
Does the tape will eventually wear out?
Old May 25, 2005 | 12:14 AM
kb798's Avatar
I got some extra tape from WW (identical to 3M's red tape), and that area right underneath the front turn signal lights is definitely a stress point for the kit. After a while, the tape can't hold the lip to the bumper as strong as it could the first day you install it. Mine went out after about a month or two, and the only solution I came up with was glue.
I used an industrial grade adhesive from 3M, and applied to directly to affected area. I held the kit up by stuffing books underneath the lip so that the glue can set itself properly. It's held up well for the past 2 months, but the only problem that I see is if I want to take the kit off, it's going to take the paint with it as well.
Old May 25, 2005 | 12:45 AM
SoOHiGH's Avatar
Default Re: Help: Buying a WW RS full kit (kb798)
the tape comes with the lip but your suppose to use rivets to hold up the lip. you dont expect double sided tape to hold the bitch up do you?
and yes they do fit good. i got mines back in 1999 for $450 brand new. sold it for $420 after a while.
Old May 25, 2005 | 03:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dongoesby &raquo;</TD></TR><TR><TD CLASS="quote">
I'm positive theres enough. I bought a roll that comes in 12yds, and there is probably 7-8yds. left on the roll..Its 3M Super Heavy Duty mounting tape, so it'll defenitly hold. I put it along the front, sides, and rear. I'll sell the rest of it to you for only $6.50 shipped I've had my lip kit on for about 3 months now, and the spot under the turn signals is still intact from the tape
Old May 25, 2005 | 08:36 AM
kb798's Avatar
Do you have pictures of where you installed the rivets?
Old May 25, 2005 | 09:34 AM
homesauce's Avatar
I'll take that tape for 6.50 shipped. Let me know where to paypal.
Old May 25, 2005 | 01:07 PM
SoOHiGH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb798 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have pictures of where you installed the rivets?
no i dont have pictures, but i used 6.
heres a picture of how i did it.
Old May 25, 2005 | 02:43 PM
Dongoesby's Avatar
Default Re: Help: Buying a WW RS full kit (SoOHiGH)
Is tape like this one I found on eBay?
http://cgi.ebay.com/ebaymotors...%3AIT
After all, I'm still worry, how do you guys take off the kit if there is still tape on it? Won't it leave some dirt on the kit, and the surface won't be flat smooth anymore?
Old May 25, 2005 | 03:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dongoesby &raquo;</TD></TR><TR><TD CLASS="quote">Is tape like this one I found on eBay?
After all, I'm still worry, how do you guys take off the kit if there is still tape on it? Won't it leave some dirt on the kit, and the surface won't be flat smooth anymore?</TD></TR></TABLE>
Its kinda like that, but it's red. The stuff I have is probably better than that
Old May 25, 2005 | 03:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">I'll take that tape for 6.50 shipped. Let me know where to paypal.</TD></TR></TABLE>
If Dongoesby doesn't want it, I'll sell it to you
Old May 25, 2005 | 03:29 PM
ludeboi121's Avatar
VIS racing bought out WW.
Old May 25, 2005 | 09:24 PM
PreLuDeSiR's Avatar
$450 is a pretty good price. if you dont buy it pm me with the seller's info and I'll pick it up. btw, where are you located?
Old May 26, 2005 | 12:50 AM
Dongoesby's Avatar
Default Re: Help: Buying a WW RS full kit (PreLuDeSiR)
i think i'm going to get it anyhow, just afraid scams. Anywayz, it is in SF
Old May 26, 2005 | 06:30 AM
Greyout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">they make some of the best body parts for cars...</TD></TR></TABLE>
they may make a nice front lip and ok sides for the prelude, but just about everything else they make is old school rice
Old May 26, 2005 | 07:43 AM
98TypeSH's Avatar
Default Re: Help: Buying a WW RS full kit (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">they may make a nice front lip and ok sides for the prelude, but just about everything else they make is old school rice</TD></TR></TABLE>
Seriously... but i really want a supra wing on my prelude. mad dorifto action. ^_^
Old Jun 1, 2005 | 10:41 AM
Dongoesby's Avatar
Default Re: Help: Buying a WW RS full kit (98TypeSH)
Thanks you guys, I got the kit for $375 because the buyer need money for an accident he just had, and also the kit has many scratches on it. I will have to sand it and repaint it. Not sure how much it is going to take thou... I would like to upload some current pics about it, but also don't know how.
808zrk
Oct 29, 2012 10:44 AM
odishaw
Acura TL, RL & ZDX
Jun 18, 2009 01:50 AM
i heart honda
Sep 8, 2008 08:21 AM
sikciv666
May 12, 2008 04:46 AM
erck
Oct 25, 2006 06:56 PM
