PieceofCrapValve
Old May 24, 2005 | 11:36 AM
Lan's Avatar
Lan
Default PieceofCrapValve
Where is the PCV on a GSR motor? year is 98 if that matters
Old May 24, 2005 | 12:47 PM
thatbluecrx's Avatar
Default Re: PieceofCrapValve (Lan)
I'm not completely sure if it is different but maybe this is right and will help you...
on a b16 it is located between the Intake Manifold runners, on the back side of the head. There should be a hose connecting it to the crank case vent.... hope its the same and this helps... if not let me know so I dont give this info to others
Old May 24, 2005 | 12:52 PM
Lan's Avatar
Lan
Default Re: PieceofCrapValve (thatbluecrx)
Thanks a lot dude... I am trying to fix a throttle air/fuel problem and I just couldn't find the little bastard.... Any suggestions on how to get it off so that I can clean it?
Old May 24, 2005 | 06:01 PM
Yea, just be careful... I was told, "just pull it out" but wen I did that, it cracked the PCV in half, leaving some in the tube and some suck in the manifold, and boy is it a pain in the *** to get it back in the crank case vent box thing... I guess do some wiggling, maybe wd-40 it or something... I woudnt bother cleaning it cause Ithink even from honda they are under 10$... but they say a way to test it is to take it off, and shake it, if you hear a little ball moving around then its good, if not, replace it...
turb0teg
Feb 24, 2010 10:13 AM
4DRmafia
Jul 28, 2005 10:24 PM
joe0509
Honda Motorcycles
Mar 7, 2004 02:29 PM
98ITR#0020
Feb 1, 2004 12:03 AM
2old_honda
Aug 25, 2003 05:09 PM
