Recently replaced valve seals leaking again
Old May 24, 2005 | 10:49 AM
quiksheit's Avatar
Default Recently replaced valve seals leaking again
When i thought the valve seals were leaking on my GSR i replaced them myself with beck and arnley brand seals. They worked great. About a year later after a a bottom end rebuild there is smoke on startup again.
Do you think it was the shitty seals?
Maybe a bad valve guide ruining the seals prematurely? IDK
What do you guys think ?
Old May 24, 2005 | 02:34 PM
ALMXDUPINTEGRA's Avatar
valve seals...try RTB
Old May 24, 2005 | 04:00 PM
quiksheit's Avatar
Default Re: (ALMXDUPINTEGRA)
what is RTB?
Maybe i should have used OEM seals. Thoughts?
Old May 25, 2005 | 02:26 AM
quiksheit's Avatar
Default Re: (quiksheit)
Bump...might be worth a leakdown?
Old May 25, 2005 | 12:19 PM
quiksheit's Avatar
ideas?
Old May 26, 2005 | 02:36 PM
quiksheit's Avatar
Found out that some engine builders around me refuse to use Felpro
Also heard that some of the new honda valve seals suck too
vinuneuro
Apr 24, 2007 06:05 AM
quiksheit
May 26, 2005 02:36 PM
D-series ninja
Jan 11, 2005 11:14 PM
