Suspension & Brakes Theory, alignment, spring rates....
Apexi N1 Coilovers
Old May 24, 2005 | 10:04 AM
1point6B's Avatar
Default Apexi N1 Coilovers
I am looking at buying a used set of Apexi N1 coilovers and just wondering if anyone has these and how they like them on the street as the car is a daily driver and going to be tracked alot after the summer is over. So if anyone has them please voice your opinion. By the way i have a EK hatch that they will be going on. Thanks.
Old May 25, 2005 | 08:37 AM
RagingAngel's Avatar
Default Re: Apexi N1 Coilovers (EK16B)
If they are the 99spec ones then they will likely ride harsher than the ones that Apex-i revalved (softer) I believe for the 00spec....
There is also the N1 Pro setup (I'm forgetting the names) with one of the biggest diameter pistons....
I've owned both sets of 99/00spec but not the N1 Pros.... they are a good damper, lightweight, I fell in love with dampers that had lower perch adjustability because of them....adjust ride height independent of main preload.
The dampening was a bit finicky, because it doesn't click or have a ****....just an allen key you're left to turn and count rotations with. All in all a good setup...particularly if you can score them at a good price.
Old May 25, 2005 | 01:41 PM
AnToNy's Avatar
A friend of mine has them on his WRX wagon and loves them.
ZoobeaR
Suspension & Brakes
Sep 1, 2005 06:27 PM
ptsaurus
Feb 19, 2004 04:03 PM
supergreenNA1
Apr 11, 2002 03:07 PM
