first few swap questions
Old May 24, 2005 | 08:51 AM
ThE PiMpiN Co's Avatar
Default first few swap questions
i had a few questions on my first swap,
im swapping in a f22b block with a h23a1 head
first, is how to i attach the tranny to the engine, the tranny is in the car, and so is the motor, but the mounts arent bolted in, and the motor cant/wont connect to the block? how do i do this? it should just slide in, right?
next, will a stock 95 si ecu work good w/o tuning it? im assuming it will since what im swapping in is pretty much a jdm dohc si motor....
then, will a h23 underdrive pulley work with the f22b block?
thats it for now, i guess ill keep you guys updated on the frankenstien swap. i hope it runs!
Old May 24, 2005 | 09:12 AM
speedracer9k's Avatar
what tranny are you using?
Old May 24, 2005 | 08:03 PM
Default Re: (speedracer9k)
h23, that should work right? i hope that wasnt the problem
Old May 28, 2005 | 10:06 AM
i dont think the h23 tranny will bolt up to the f22 block, the splines might be different, try a serach
aftershock2686
Jul 3, 2007 06:16 PM
itsapeace
Dec 14, 2006 02:02 PM
chalkboard
Apr 12, 2005 05:50 AM
CRXSiR71777
Feb 22, 2005 07:33 PM
FadedEpic
Aug 21, 2004 12:58 AM
