injectors????
Old May 24, 2005 | 04:51 AM
sonek's Avatar
Default injectors????
i have a 02 si w/ a stage one rev hard kit,custom 3'' exhaust pipingw/ a 3-in,4-out magnaflow,nology plugs and wires and a couple other things that havent been installed yet...
i am geting a k pro upgrade a.s.a.p.
do i need any thing else besides a boost control,to get a reliable 10-11psi
fuel regulator,fuel pump,motor mount inserts,axels or injectors????
i was going to just get the injectors,regulator,pump and k-pro..any ideas ?
Old May 24, 2005 | 05:50 AM
kung fu grip's Avatar
Default Re: injectors???? (sonek)
oy.
Old May 24, 2005 | 07:22 AM
Atlas's Avatar
the kit doesn't include injectors? that sucks.
you need 550 or 650 injectors. you could use 440 injectors, but i personally wouldn't because they can get over worked very quickly, and if your going to be running 10-11 pounds, 550s may be a little to small in the upper RPM ranges.
a Walboro 255lb fuel pump would do the trick for the fuel pump, but you probably won't need one if you saty around 10 pounds.
the k-pro (besides the AME EMS) is the best tuning tool out there (in my opinion). you NEED this to tune any k-series turbo motor to its potential. its very easy to use, just make sure you have a decent laptop.
Old May 24, 2005 | 12:09 PM
krystar's Avatar
even our typeS stock 330 injectors max out at even less than 5psi. u have a 270 inject and turbo?? what turbo kit doesn't come with injectors??? did u get this new or used?
Old May 24, 2005 | 02:13 PM
sonek's Avatar
the kit came with 440,s but im thinking i need a bit more..
i want to boost more than 7psi without doing damage to my motor.
and does anyone know some one in jersey that will make me a custom 3'' turbo downpipe
Dom_GsR
Jun 22, 2012 06:50 AM
b16b18
Sep 3, 2008 07:38 AM
slowtegkauai
Mar 31, 2008 10:38 PM
h22acivicman
Apr 6, 2004 08:00 PM
smoothludey2
Sep 6, 2001 06:48 PM
