Turbo F22 checklist
Old May 23, 2005 | 09:46 PM
Midnightrayne's Avatar
Default Turbo F22 checklist
I am fixing to turbo my f22 and i was wondering is there a check list for doing this? the kit comes with i assume everything i need, are there any tips or tricks for this engine?
Thaanks.
Old May 23, 2005 | 11:07 PM
i_kick_turtles's Avatar
Default Re: Turbo F22 checklist (Midnightrayne)
http://www.cse.uconn.edu/~yele....html
Old May 24, 2005 | 12:09 AM
raceACCORDingly's Avatar
compression test
Old May 24, 2005 | 05:31 AM
Default Re: (raceACCORDingly)
for the compression test what should a stock f22 have?
Old May 26, 2005 | 10:27 AM
DUKE's Avatar
Default Re: (Midnightrayne)
it should be in running condition lol. Any garage can do it for you for a little fee. All your psitons should register over 160 after the comprassion test do a leak down test. Good luck
Old May 26, 2005 | 12:51 PM
it depends but the readings should all be pretty close to each other.
Old May 26, 2005 | 08:07 PM
twkdCD595's Avatar
they should be within about 10% of each other...
I would perform all the basic routine maintance stuff if you have not already... fresh spark plugs (step down a heat range), fuel filter, cap/ rotor, check your cv boots, etc.
Maybe think about getting some little stuff out of the way like some slim radiator fans, a catch can , fuel pump and fuel pressure regulator, etc... little stuff you know you want to do, stuff that will not leave you without your ride or a bunch of downtime.
Old May 27, 2005 | 03:45 AM
jmal1919's Avatar
Alternate means of transportation. That way, you don't rush the situation if something comes up.
Old May 27, 2005 | 01:29 PM
Default Re: Turbo F22 checklist (jmal1919)
yeah not rushing want to get everything first then turbo the car, the turbo could sit for months i dont care as long as everything is gonna work well when its done.
Looking at getting an equal lenght exhaust manifold for a 92 anybody know how much and where?
itr590
Nov 30, 2007 03:28 PM
b18bme
Apr 6, 2006 11:01 AM
txl146
Apr 28, 2005 05:53 AM
InLimbo87
Jun 19, 2004 01:50 PM
