Vacum leak!
I have a severe vacum leak, My idle raises and lowers by itself and there is a distinct hissing sound, somewhere by the intake. Today i started pulling off every hose and trying to find the problem, But nothing.
Whats the best way to look for a vacum leak?? and anyone else have similar problem and what was your plan to fix the situation?
Thanks
90 integra B18 Obd1
Thanks
90 integra B18 Obd1
i dont think pulling hoses will help you find the problem. i use carburator spray to find vacuum leaks. try that.. a can isnt too expensive. just make sure you dont spray on anything hot or you might risk catching the motor on fire. hope that helps a little
