UKDM ITR Cluster - ABS Light Stays On
I just bought a UKDM ITR cluster and changed the green film in the back. We'll my ABS light stays on all the time now. I wasn't sure if it was plug in play with my 97 Integra so I changed them. Here's a pic to show you what the back of it looks like. The bulb on the top left is the icon that shows that your doors are open. Right next to that is the abs icon. Do I have to take that little panel off to get to the bulb? I didn't want to mess with it and break something. Also, I'm not sure if my bulb was dead or not on my last cluster so there could be something wrong with my ABS system.
But basically the question is, is that normal to happen when changing clusters from a different country?
It's possible that the ABS light for the UKDM cluster is triggered by a different circuit from your harness (seat belt light, for example). Trace the ABS bulb circuit from your original cluster and compare it with the circuit from the new cluster. Make sure they go to the same pin on your dash connector. If not, you may need to swap pins. If so, try plugging your original cluster back in and turn the ignition to the on position and watch for the abs light. This puts it into bulb check mode, where all the lights come on for a few seconds, then turn off. This is where you can verify if your bulbs are all working.
utturkey
May 25, 2011 05:42 PM
EM199dcs
Jan 25, 2007 10:58 AM
Prod
Nov 4, 2004 03:09 PM
