I need fuse panel number for parking lights. Weird problem here.
Ok. The guy i just sold my integra to is having some issues. I am baffled because i never had this problem, but he said the parking lights and dash light just quit on him.
I asked the obvious...did you check fuses, etc. He said yes with a test light. Apparently it didn't have the diagram for the fuses, i never had a blown fuse so...i was at a loss. He did say it happened shortly after he put in the headunit.
I am 99.99% its a fuse that was overlookedor checked improperly, anyone have the number for the parking lights and dash lights fuses? I used to have the list of all the fuse numbers but can't find it..UgH!!
TIA!
TIA!
he hooked the dimmer up wrong and poped the fuse, look under the hood in that fuse box, or something like that
he was using a plug and play harness.
The fuses under the dash are numbered. I am trying to find the numbers to relay to him. He didn't actually pull the fuses he just used a test light, i guess checking for continuity...Shitty thing is he is 2 hours away..or i would go fix it
I am guessing he pinched the dimmer sliding it in maybe..? I told him to pull the radio tomorrow, but he said no fuses were blown..i think it was overlooked IMHO. That is why i wish i could go double check you know..
Heart4Tuners
Jul 24, 2011 11:33 AM
