Turbocharging my CRX
Old May 23, 2005 | 01:26 PM
SirThelin's Avatar
Default Turbocharging my CRX
Hey
I´ve got a Crx with an D16z5 DOHC
Really itchy for a turbocharger.
Searched at Sportscompactonly.com and found a kit for d16a1.
U think it will work?
Old May 23, 2005 | 02:06 PM
Mach69's Avatar
Default Re: Turbocharging my CRX (SirThelin)
I have no idea what a D16Z5 is! I am not sure if it exists. However, you mentioned that it is a DOHC engine, and the only D-series DOHC engine was the ZC. Is that a D16z5?
If you are talking about the ZC dohc, then that is a great engine to turbocharge. You can piece together a hmt kit.
http://www.homemadeturbo.com/
Old May 23, 2005 | 07:39 PM
HiProfile's Avatar
Default Re: Turbocharging my CRX (Mach69)
A kit for a d16a1 will fit any mpfi d16 (has same exhaust manifold, and nearly the same t-body placement). Eigher you have a ZC DOHC or a SOHC D16z6, either way it will work. The only reason it wouldn't work 100% is bacase the a1 is from an 86-87 teg, and I'm sure teh charge piping would be different. Regardless, the a1 swaps right into a crx, so I'm sure you'll be fine.
Old May 23, 2005 | 09:11 PM
Mach69's Avatar
Default Re: Turbocharging my CRX (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">the a1 swaps right into a crx</TD></TR></TABLE>
It swaps in, yes. But not right in. It is a really pain to get the A1 into the crx body, or so I have read. Its not the 'drop-in' like a z6 or ZC engine is.
As far as exhaust manifold and throttle body placement, those are probably the same.
Old May 23, 2005 | 09:18 PM
markdman's Avatar
the a1 actually drops right into the 84-87 crx's. the 88-91 a little fab is needed
Old May 23, 2005 | 09:20 PM
markdman's Avatar
oh yeah, if your not sure it will work, buy a d16a1 exhaust gasket and see if it will fit on your z5
Old May 28, 2005 | 08:09 AM
SirThelin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea what a D16Z5 is! I am not sure if it exists. However, you mentioned that it is a DOHC engine, and the only D-series DOHC engine was the ZC. Is that a D16z5?
http://www.homemadeturbo.com/</TD></TR></TABLE>
I didnt know that my D16z5 existed before i checked my papers and doublechecked on th block.....It really exist.
So I can bolt on the turbo that fit on the a1 and zc then?
Old May 28, 2005 | 03:45 PM
juice91si's Avatar
you have a z5, it was only available in europe, thats why you confused the ppl above. like already mentioned too, everything should bolt up fine. its a d-series so the ex mani will work fine, it is very similar to the jdm zc.
90crxsi88zc
10
Jun 10, 2006 06:23 PM
mr_valentino20032000
Jul 22, 2004 04:03 PM
89sirex
Jul 7, 2004 02:30 PM
joeD
May 23, 2004 02:35 PM
Creepshow S60
21
Oct 18, 2003 10:42 AM
