h22 flywheel help
I have an XTD Flywheel i bought for my h22 swap and I went to put it on but the dowel pin didn't fit correctly... is this normal? or should the dowel pin move? The flywheel bolt patter fits correctly but the dowel pin doesn't... Anyone with some help would be appreciatied
There are 8 bolts that hold the flywheel on... and one dowel pin.... The dowel pin hole won't line up... what will roatating do if i only have 1 dowel pin hole??? it's off by 1/8"... If you line the flywheel up with the dowel pin the holes are all off
they must have machined the flywheel wrong. this happened with a batch of flywheels from Clutchmasters with me a long time ago. i would tell the company you ordered it from or tell XTD directly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st95accord »</TD></TR><TR><TD CLASS="quote">There are 8 bolts that hold the flywheel on... and one dowel pin.... The dowel pin hole won't line up... what will roatating do if i only have 1 dowel pin hole??? it's off by 1/8"... If you line the flywheel up with the dowel pin the holes are all off</TD></TR></TABLE>
Yeah, sorry about that. I thought you meant the outer holes....looks like it is a manufacturing error.
I also had the same problem with the 12 lb. XTD flywheel I got about 2 months ago for my prelude. I didn't have time to wait for a new one, so the shop that installed mine ended up enlarging the hole. It seems to be OK so far... Knock on wood.
