motor install fees??
swaps in the new england area charge between $600 and $1000. I'm sure shops that do swaps more often will charge less.... just get some friends together one day and do it in the garage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 »</TD></TR><TR><TD CLASS="quote">do you know any good cheap places (cites) that i could buy a b18c5 off of?</TD></TR></TABLE>
this is where i bought mine
http://www.hmotorsonline.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 »</TD></TR><TR><TD CLASS="quote">why do people hate swapping type r motors</TD></TR></TABLE>
because they dont have one.. thats why
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo »</TD></TR><TR><TD CLASS="quote">drop it in yourself for way cheaper</TD></TR></TABLE>
if he doesnt know how, this isnt a bad way to go.. plus if you go to a repratable(sp) shop, they will warranty there work..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 »</TD></TR><TR><TD CLASS="quote">how much does it cost to have a shope drop in a motor??</TD></TR></TABLE>
FSM - $70
Labor - 8hrs
Learning how to swap an engine - Priceless....
FSM - $70
Labor - 8hrs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 »</TD></TR><TR><TD CLASS="quote">did you buy th b18c 94-97 complete swap?? if so did u have to end up buying some other parts??</TD></TR></TABLE>
yeah i got the 97 spec complete swap. i had to buy placeracing mounts, and hasport cable to hydro conversion kit in order for me to run the itr tranny
usually cost engine price + about 600-700 labor.
anybody know if i can put a b18c5 head on a b18c1, i bent all my valves and im just going to rebuild a little bit stronger. i need some advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Str8clowninGSR »</TD></TR><TR><TD CLASS="quote">usually cost engine price + about 600-700 labor.
anybody know if i can put a b18c5 head on a b18c1, i bent all my valves and im just going to rebuild a little bit stronger. i need some advice</TD></TR></TABLE>
ofcourse you can
ofcourse you can
its about 7 to 8 hours of labor, but you have factor in any wiring that has to be done, unless you are including a harness, then they add the labor of adding that in, some places will do it for cheap to add that, since the engine will be out already. Up north they charge about 80 an hour to do a swap, I charge about 350 to 400 depending on what needs to be wired and I hook people up on some stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 »</TD></TR><TR><TD CLASS="quote">so how much did all those extra parts and the motor plus install end up costing u?</TD></TR></TABLE>
i spent an extra $500 just for the parts alone. my buddy and i installed it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 »</TD></TR><TR><TD CLASS="quote">where did u get those place racing motor mounts from??</TD></TR></TABLE>
from http://www.placeracing.com
