Suspension & Brakes Theory, alignment, spring rates....
custom endlinks
Old May 23, 2005 | 12:35 PM
EeeJayEight's Avatar
Default custom endlinks
so i made custom endlinks for a gsr rear sway bar to be installed on a 96 civic ex... since i couldnt find Si endlinks...
my question is what is the length of the stock 99-00 si endlinks and would lengthening or shortening the ones i made affect the handling??
i used those bolts that look like eyebolts and have bolts through them... i cant remember the name at the moment but i can get pictures...
anyways, i was wondering if i should shorten them or what if i wanted a better handling sway bar
Old May 23, 2005 | 02:15 PM
RineRacing's Avatar
Default Re: custom endlinks (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">
Rod ends, heim joints, sperical bearings? I assume you mean one of these.
http://www.aurorabearing.com/
You want to set your endlinks to be as perpindicular to the LCA as you can.
Like this "|", not "\" or "/".
Old May 23, 2005 | 11:34 PM
Default Re: custom endlinks (RineRacing)
thanks.. ill check it out
Old May 24, 2005 | 07:19 AM
94eg!'s Avatar
#1 Super Guy
Loved
and you want your swaybar arms to be perpendicular to your endlinks when the car is sitting on level ground...
Any change in either the end-link angle, or swaybar arm angle will result in less twisting of the sway-bar during operation. This will effectivly reduce the stiffness of the sway-bar (not much though)...
Old May 24, 2005 | 04:57 PM
Default Re: custom endlinks (94eg!)
appreciate the help guys
commguy
Suspension & Brakes
Aug 15, 2007 08:00 PM
Beau Gotti
Suspension & Brakes
Nov 5, 2006 10:18 PM
SickWitIt2.0
Apr 2, 2006 05:49 PM
rough_draft
Northwest (Sales)
Sep 20, 2005 10:24 AM
