*^*^*^*B and D Garage Sale*^*^*^*
ALL PRICES ARE NOT SHIPPED UNLESS STATED
Del Sol Airbag, same as all EG's, Any reasonable offer
GSR IAB $50 brand new GSR timing belt $25 IACV $15 Clutch slave cyl w/ line $15 EG radiator hold down $5 B series Auto starter $40
B16A2 OBD1 Si-R2 Inatke Manifold, includes IACV and IAT $40
B20 Intake Manifold, includes TB w/o Map or TPS, Fool Rail, Fuel Line and IAT $30 ( good for ghetto ITB's)
B16A1 OBD0 Si-R Intake Manifold, Bare $20 (good for ghetto ITB's) D16Z6 Intake Manifold, Bare $25 GSR cam gears $20 pair
civic/integra rear upper control arms, good bushings $20 pair
2 pairs of PS pump brackets $10 pair
obd0 Si-R B16 A/C compressor (spins free and clutch works) $25 and B series Starter $75
EF9 Si-R Stock intake tube and top of filter box $20
Obd1/2 A/C compressor same as the other one $25
obd0 Si-R B16 intake manifold $20
Drivers EK upper control arm (used a little but ball joint still real tight) $15 EK fuel rail $10 obd2 dizzy, missing module $15 obd1 sohc rear mount $20
obd0 Si-R b16 Tranny mount $15 obd1 sohc and dohc tranny front mounts $20 each
D16y8 block ( needs to be bored, detonated) comes with block saver, crank, and arp studs. needs nuts and washers for the studs. you can but them direct from art for ~$30, $150
Modified by funkfnamna at 7:20 PM 5/23/2005
Modified by funkfnamna at 8:42 PM 5/25/2005
Modified by funkfnamna at 11:12 AM 5/26/2005
Modified by funkfnamna at 2:49 PM 5/27/2005
Modified by funkfnamna at 7:08 PM 6/2/2005
Modified by funkfnamna at 3:04 PM 6/3/2005
