Easiest way to run Rywire harness thru firewall? (Without cutting the wires)
Old May 23, 2005 | 11:22 AM
Exempt's Avatar
Default Easiest way to run Rywire harness thru firewall? (Without cutting the wires)
For my D15B VTEC swap into my 91 CRX Si, I bought one of these:
http://www.rywire.com/sitodvtec.shtml
Which came with all that I needed to convert to OBD1... But my only problem is, it came with the connectors already attached for VTEC... Which Im glad, this is a good thing... But I cant figure out how to run the harness thru the firewall without cutting off the black plug and resplicing them on the other side... Does anybody have any other ideas?
Heres some pics of the black plug I am talking about...
And one of the dirty engine bay for the road!
Thanks in advance!
Old May 23, 2005 | 01:59 PM
v.i.gsr's Avatar
Default Re: Easiest way to run Rywire harness thru firewall? (Exempt)
try to snake it threw from inside out, with the wires going threw the firewall from the inside of the car, to the engine bay
Old May 23, 2005 | 05:30 PM
91civicDXdude's Avatar
you could always depin and repin the wires which would take like 2 seconds
Old May 23, 2005 | 05:45 PM
Rywire's Avatar
Default Re: (91civicDXdude)
Take off the charcol canister from the firewall, you can feed it through the ac line hole, or the factory harness hole, your choice.
I always use the ac hole if the car has no ac...
Ryan
Old May 23, 2005 | 06:06 PM
Exempt's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Take off the charcol canister from the firewall, you can feed it through the ac line hole, or the factory harness hole, your choice.
Ryan</TD></TR></TABLE>
Since im going OBD1 do I even need that charcol canister? Or can I just remove it altogether?
But thanks guys... Since I want to keep A/C Ill probably try and feed it thru the factory harness...
Old May 23, 2005 | 07:24 PM
Rywire's Avatar
Default Re: (Exempt)
Yes, keep the canister, its for smog
Old May 23, 2005 | 08:06 PM
Exempt's Avatar
K... Thanks for the help man!
Old May 23, 2005 | 10:23 PM
Rywire's Avatar
No prob, good luck!
Dark_Teg
Engine Management and Tuning
Aug 23, 2010 06:07 PM
94-integra-ls
Sep 17, 2009 05:23 AM
WickedWerx
Nov 1, 2004 08:18 PM
jahnericm
Mar 26, 2004 07:53 PM
freeeked
Aug 30, 2003 02:27 AM
