I need some info for my EF conversion
Old May 23, 2005 | 10:51 AM
JoeHatch's Avatar
Default I need some info for my EF conversion
to drop my ls motor in my civic hatch what kind of motor mounts do i need, i heard that ANY Bseris mounts will work is this true? And my car is still Dual Point i have the wireing hareness for the outside do i have to change the inside wires to my car as well when i am converting it to LS???
Old May 23, 2005 | 11:07 AM
beyondspexj's Avatar
any bseries mounts will work that are made for the swap. like enjo mounts, avid racing mounts, or hasport mounts.
you will need a ecu conversion harness that you can get from boomslang
Old May 23, 2005 | 11:19 AM
EP3_05's Avatar
Default Re: I need some info for my EF conversion (LSCivic#1)
Any swap mounts will work ie HAsport, HCP, Enjo, etc
As for the dpfi->mpfi swap check this thread out:
https://honda-tech.com/zerothread?id=639552
Old May 23, 2005 | 12:45 PM
tallguy's Avatar
I love my enjo's, there a little harsh but they get the job done.
Old May 27, 2005 | 08:35 AM
JoeHatch's Avatar
Default Re: I need some info for my EF conversion (tallguy)
do you know if a GSR fuel rail wil go on my ls intake manifold and work properly?
Old May 27, 2005 | 08:49 AM
slimer007's Avatar
It should all B series fuel rails are same ( I think). I know the injectors are.
Old May 28, 2005 | 04:23 PM
Bull_head360's Avatar
joe, the fuel rail will work since they're the same, and btw, i printed out a DPFI to MPFI "How-To" so we're set, also i sent you some links in PM
Old May 28, 2005 | 04:32 PM
Hamstr323's Avatar
Default Re: (Bull_head360)
u can buy mounts,axels,linkage,harness, http://www.swapshopracing.com
Old May 28, 2005 | 04:45 PM
kaoss_11's Avatar
B A N N E D
i like my place racing mounts
Old May 28, 2005 | 05:01 PM
Hamstr323's Avatar
Default Re: (kaoss_11)
to bad place went out of buisness
Old May 28, 2005 | 06:40 PM
NikoZai's Avatar
Default Re: (Hamstr323)
http://www.rywire.com for your engine harness, we'll explain it all to you. Give us a call and get Hasport mounts.
i-VTEC racer
Oct 29, 2014 04:38 PM
dano3104
Feb 5, 2012 05:00 PM
JDMIntegR1
Feb 5, 2005 03:18 PM
crex23
Aug 8, 2003 08:11 PM
