apexi ws cat-back question
Old May 23, 2005 | 08:42 AM
worditsmenick's Avatar
Default apexi ws cat-back question
i have had my apexi ws cat-back on my for about 2.5-3 years. when i first put it on i noticed that the car raddled alittle from the cat-back. well now the car raddles and shakes alittle when im in rev or at idle w/o brake on.
does anyone else have this problem?
i just want to pin point the cause of the raddle.
Old May 23, 2005 | 08:56 AM
sooo_slow's Avatar
New User
Default Re: apexi ws cat-back question (worditsmenick)
does ur shifter hit the piping at all?
Old May 23, 2005 | 09:21 AM
its a auto.
Old May 23, 2005 | 11:34 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
could be that one of the heat shields under there are loose, get under there and check it out
Old May 23, 2005 | 12:05 PM
yeah i will. i thought that i got all them out of there when we installed it. but yeah thanks i will check out the underside.
Old May 23, 2005 | 12:12 PM
bottlefed13's Avatar
Default Re: (worditsmenick)
i have 2.25 piping too. the rear section of it near the muffler rattles against the underside of the car. i don't know what it's hitting though. it gets annoying at times but i deal with it.
Old May 23, 2005 | 12:27 PM
BuyImports2's Avatar
all my heat shields are out, and mine still rattles a little bit. i can only notice it at idle. how bad is it? i suppose if you were really dedicated, you find out where exactly it is rattling, then put some heat wrap over it to pad it.
Old May 23, 2005 | 02:33 PM
Default Re: apexi ws cat-back question (BuyImports2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuyImports2 &raquo;</TD></TR><TR><TD CLASS="quote">all my heat shields are out, and mine still rattles a little bit. i can only notice it at idle. how bad is it? i suppose if you were really dedicated, you find out where exactly it is rattling, then put some heat wrap over it to pad it.</TD></TR></TABLE>
it really has nothing to do with being dedicated or not. the piping was made wider. therefore it rattles once in a while. not a major problem to me. it only rattles at idle once in a while.
Old May 23, 2005 | 03:34 PM
The_Nomad's Avatar
Default Re: apexi ws cat-back question (bottlefed13)
Sometimes it's just a little adjustment of the hangers that could cure it.
On my Miata the Jackson Racing cat back has hangers that are right angle rods that go through the rubber hangers. So the whole exhaust can "creep" over to the right in time and start to rub on the body.
I went under there and put hose clamps on the rods that keep it from moving around. Problem solved.
dawrenn
Feb 20, 2005 11:07 PM
MrCivic98
Jan 18, 2004 10:38 AM
valentinecr
Jan 12, 2004 04:52 AM
Euro98ITR
Nov 28, 2002 06:06 PM
Duck Sauce
Dec 4, 2001 12:45 AM
