HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP
Old May 23, 2005 | 05:38 AM
hacuramonkey's Avatar
Default HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP
Yes, I did a search, but it wasn't helpful to me. I searched for wheel spacers, hub spacers and the only thing I could find are H&R ones. I have a 97 Integra, with Skunk 2 extended wheel studs. I put some hx wheels on but they hit the front brake caliper bracket. Since I have the extended wheel studs, I cant use the H&R spacers. I could shave some off of the bracket, but it would be nice to bring the wheels out anyway. Has anyone had a similar experience and a solution?
Old May 23, 2005 | 11:14 AM
rotten's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (hacuramonkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hacuramonkey &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I did a search, but it wasn't helpful to me. I searched for wheel spacers, hub spacers and the only thing I could find are H&R ones. I have a 97 Integra, with Skunk 2 extended wheel studs. I put some hx wheels on but they hit the front brake caliper bracket. Since I have the extended wheel studs, I cant use the H&R spacers. I could shave some off of the bracket, but it would be nice to bring the wheels out anyway. Has anyone had a similar experience and a solution?</TD></TR></TABLE>
What do you mean you can't use H&R wheel spacers? Of course you can. They require extended wheel studs--all spacers really should be using them. The thing is H&R's usually come with the studs is all.
H&R sells a couple of really big spacers that require different mounting setups, but the type that you're going to need (i.e. 5mm or so) is not going to be a problem.
-k
Old May 24, 2005 | 01:58 AM
hanson said's Avatar
you don't need to buy spacers.
you can shave a few mm(3, i think) off of your brake calipers and the hx wheels fit just fine. as far as i know the caliper trimming is safe and not done on areas that would be dangerous.
it's easier, cheaper, and in my eyes safer. less leveraged stress on the studs.
try a search for more information.
Old May 27, 2005 | 04:47 PM
Gqracer's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (hanson said)
just put on spacer. its only 5 bux each at local tire shop..
Old May 28, 2005 | 06:06 PM
bottlefed13's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (Gqracer)
anyone have pics?
Old May 29, 2005 | 05:05 PM
Wes V's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (bottlefed13)
You asked, here it is;
This is on my 89 civic hatchback with DA brakes (with EX spindles). The caliper bracket has been "clearanced".
Wes
Old Jun 29, 2005 | 06:11 AM
stmotorsports's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (Wes V)
very nice to the gunmetal hx rims
back on topic, I guess it depends what you're looking to accomplish- true the spacers will put additional stress on the studs, but it will also increase your overall track width by double the width of each spacer (one on each side-duh). It doesn't sound like alot, but if you're planning on doing autox and/or track stuff with the car, every little bit helps. Especially with those skinny hx rims. Of course you could always run even thicker spacers, get the hx wheels widened and squeek some wider tires on there
but most people just grind down the caliper :dunno:
Old Jul 5, 2005 | 01:38 AM
iHATEspeedbumps.'s Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (stmotorsports)
so hx's dont fit over integra calipers?
Old Jul 5, 2005 | 08:55 AM
Preferio's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (iDISLIKEspeedbumps.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iDISLIKEspeedbumps. &raquo;</TD></TR><TR><TD CLASS="quote">so hx's dont fit over integra calipers?</TD></TR></TABLE>
Old Jul 5, 2005 | 04:16 PM
TRIppinHonDA's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (95IntegraLSR)
nice
Old Feb 15, 2006 | 02:16 PM
sockvtec's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (01CBRF4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hanson said &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to buy spacers.
try a search for more information.</TD></TR></TABLE>
horrible info
dude freakin some h&r or eibach 5mm spacers with the extended studs is by far the safest and easiest way to go.....maybe not as cheap, but IMO best way to go
Old Feb 15, 2006 | 02:17 PM
sockvtec's Avatar
Default Re: HX WHEELS ON INTEGRA WHEEL SPACERS 4x100 HELP (iHATEspeedbumps.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHATEspeedbumps. &raquo;</TD></TR><TR><TD CLASS="quote">so hx's dont fit over integra calipers?</TD></TR></TABLE>
not without spacers
or shaving caliper
00MRSi
Jan 14, 2009 01:24 PM
2-7offsuit
Suspension & Brakes
Nov 25, 2005 01:43 AM
Civic Hx-T
12
Aug 27, 2003 07:33 PM
12 oz.
May 19, 2003 03:18 PM
