will this work
Old May 22, 2005 | 10:31 PM
R_type's Avatar
Default will this work
can i use my altenator and crank pulley from my d16a6 and run that on my jdm d15 or that wont work cause its obd0 ****
Old May 22, 2005 | 10:43 PM
FalkenSiR's Avatar
Default Re: will this work (R_type)
It shouldn't. You may want to get both engine's wiring diagrams and match them or try ask people who have done it...
Old May 22, 2005 | 10:45 PM
blah13's Avatar
Default Re: will this work (fast88std)
Depends, are you running an obd-0 ecu? If so then yeah, if you converted to obd-1 then no. And yes the crank pulley should work.
Old May 22, 2005 | 11:25 PM
92integra_gs's Avatar
both of them should work... i would check for maybe clearance tho for the pulley just making sure its compatible to swap around...
oXeNo
Mar 30, 2012 01:38 PM
Brown Rock
Dec 30, 2011 11:02 PM
budomove
Nov 2, 2007 07:37 PM
Eibach95Civic
Aug 31, 2003 02:41 PM
