95 Integ LS/VTEC Turbo idle problem...
Old May 22, 2005 | 10:21 PM
JeffRocksYoSocks's Avatar
Default 95 Integ LS/VTEC Turbo idle problem...
I just put the aebs typhoon mani, str fuel rail, and the hondata mani gasket, and now the idle is all jacked up. at cold it idles fine, then when its warmed up the idle fluctuates between 800-1300 rpm. Checked and cleaned the iacv, checked for vacuum leaks, checked all sensors, no check engine light, reset the ecu, and nothing. aaahhh im so confused. hahaha can someone please help me.
Old Jun 6, 2005 | 06:03 PM
gtowni3's Avatar
Default Re: 95 Integ LS/VTEC Turbo idle problem... (JeffRocksYoSocks)
is it a stock bottom end? what kind of head
Old Aug 1, 2005 | 12:05 PM
LSVtecHatchback's Avatar
adjust the cold start
Old Aug 1, 2005 | 02:31 PM
rdeezy78's Avatar
Default Re: 95 Integ LS/VTEC Turbo idle problem... (LSVtecHatchback)
Also theres a little rectangle shaped box looking thing on front of mani. inside there is a little white thing not sure what it's called but sometimes it comes loose. tighten that up and you might be in good shape. That's happened to me and after that my car purred like a kitten.
98bucket
Sep 27, 2013 02:19 AM
DO/\/\O
14
May 9, 2011 05:56 PM
B18_badboy
May 1, 2011 04:43 PM
lilCivic
Feb 2, 2005 05:36 PM
luvimports
Nov 9, 2004 12:23 PM
