What kind of paint should i use to paint my ITR valve cover!!
Old May 22, 2005 | 09:54 PM
Edward's Avatar
Default What kind of paint should i use to paint my ITR valve cover!!
My ITR red valve cover faked. I want to repray it as standard. How can i do it?? Which color code/name and which brand should i use?
Thanks for your help!!
Old May 22, 2005 | 10:03 PM
esponet's Avatar
vht wrinckle red. you could et it through summit, if you can't find it at your local store.
Old May 22, 2005 | 10:13 PM
KayOs's Avatar
Default Re: What kind of paint should i use to paint my ITR valve cover!! (Edward)
Get it powder coated candy apple red--
Old May 23, 2005 | 03:05 PM
Edward's Avatar
Anyone?
Old May 23, 2005 | 03:08 PM
RTW DC2R's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">VHT wrinkle red. you could et it through summit, if you can't find it at your local store.</TD></TR></TABLE>
Old May 23, 2005 | 03:15 PM
Finland's Avatar
VHT, or I used dupli color black. Be forewarned, the learning curve is very steep on wrinkle finish paint, be prepared, and buy enough material to do the job about 3 times...and buy a heat gun.
Old May 29, 2005 | 01:18 AM
Edward's Avatar
Finished paint job. Thanks for you guys!!
Old May 29, 2005 | 08:15 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
so did you use that vht crinkle red?
Old May 29, 2005 | 10:06 AM
Hybrid ctr's Avatar
Default Re: What kind of paint should i use to paint my ITR valve cover!! (not so civic)
came out pretty nice... good job!!!
Old May 29, 2005 | 10:33 AM
grnlion's Avatar
did you use a dremel to clear up the letters?
Old May 29, 2005 | 10:47 AM
kaoss_11's Avatar
B A N N E D
Have it color matched
Old May 29, 2005 | 02:23 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (kaoss_11)
Orange! CONE!
Old May 29, 2005 | 02:25 PM
1993sir05's Avatar
Default Re: (grnlion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grnlion &raquo;</TD></TR><TR><TD CLASS="quote">did you use a dremel to clear up the letters?</TD></TR></TABLE>
why not tape them off?
Old May 29, 2005 | 02:27 PM
Stunna BEN's Avatar
Default Re: (1993sir05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir05 &raquo;</TD></TR><TR><TD CLASS="quote">why not tape them off?</TD></TR></TABLE>
Why not shave them off all together?
Old May 29, 2005 | 03:11 PM
UH8MYVTEC's Avatar
Vasoline works for masking the letters off.
Old May 29, 2005 | 11:43 PM
KOALA YUMMIES's Avatar
Default Re: (UH8MYVTEC)
I dont get it he posted this thread on 5-15
https://honda-tech.com/zerothread?id=1246447
Heck even the ground wires for the spark plugs are in the same shapes!
and the pic of the valve cover looks nearly the same in the thread he just made.
Old May 30, 2005 | 06:37 AM
tommymoose's Avatar
Default Re: (KOALA YUMMIES)
^ I just analyzed both pics, and they're definatley two different pics. That job came out awesome then because it looks stock
Old May 30, 2005 | 09:06 AM
Default Re: (tommymoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">^ I just analyzed both pics, and they're definatley two different pics. That job came out awesome then because it looks stock </TD></TR></TABLE>
I never said they werent too different pics, I was implying that by the look of the spark plug and other wires it looked like he never even pulled off the valve cover. I know they're two differnt pics if you right click and see the url you didnt have to bust out your mad photo analyzing skillz.
Old May 30, 2005 | 09:14 AM
Hulkmanj99's Avatar
i cannot find a difference in he pics at all. if you could show me what you found different case its buggin me now!!
Old May 30, 2005 | 09:33 AM
JDMSpoonType-R's Avatar
I can't see a difference at all, the spark plug wire grounds are the exact same in both pics and so is the spot next to the "H" on the "HONDA."
I'm not saying he didn't paint it, just saying the pictures are the same.
Old May 30, 2005 | 01:47 PM
Default Re: (Hulkmanj99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkmanj99 &raquo;</TD></TR><TR><TD CLASS="quote">i cannot find a difference in he pics at all. if you could show me what you found different case its buggin me now!! </TD></TR></TABLE>
Exactly, theyre the same valve cover from his photos before, there is not difference!
Old Mar 12, 2006 | 07:00 AM
Racermech's Avatar
Check out the brown-ish breather hose. It goes in two different directions. Also there is a while/silver line that is in the second pic, but not the first. It looks like it is from the intake to the dizzy(?)
EDIT: I dont know why the hell i bumped this, not even sure how i viewed it as I was not searching for info on painting....sorry for being the morning idot!
Modified by Racermech at 8:25 AM 3/12/2006
Old Mar 12, 2006 | 08:40 AM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Man I just love how no matter what it is or is about, There is always someone wanting to doubt the word/work of others on here and try to prove otherwise. Why is that? Rather than come to read or enjoy the board people would rather WASTE time investigating a pic to see if its the same or not.
Who really cares if he repainted it or not, If he did in fact respray it he done a great job. Give the guy props......
Old Mar 12, 2006 | 09:00 AM
Default Re: (01ITR#173DC2ning)
The only reason it was doubted is because it looks like a brand new OEM (JDM) cover and if thats the case everyone's going to be dissapointed when they try to use the wrinkle paint and find out its a lot harder to use and get consistant good results, that looks like brand new OEM, and I've used the paint and its very hard to get good consistant results.
BTW this was a bad reason to bring back from the dead.
Old Mar 12, 2006 | 10:27 AM
JjuuN R's Avatar
lol, you guys are looking too far into this
