stock airbox modification
Through searching, I saw that people have done things such as remove the inner divider in the stock air box. Has this proven to be an effective modification, especially when combined with an extension such as the spoon or J's? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">doesn't the inner divider just keep the filter from moving? i'll go look at my box later to make sure</TD></TR></TABLE>
The inner divider helps prevent the birds that get in there from pecking at your filter.
you can remove the top cover, although it will draw in hot air from the engine bay and will cost a negative of around 2-3 HP. However, it makes a very good sounding grumbling noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
The inner divider helps prevent the birds that get in there from pecking at your filter.</TD></TR></TABLE>
with stock airbox and no snorkel, i don't see that happening
i did the airbox mod and used the spoon snorkel...it worked great...just remember to clean the filter more often
and check the airbox for rocks and other debri
afv91
May 26, 2011 05:54 PM
rev limiter
13
May 1, 2005 11:53 PM
