Bent valves?
Old May 22, 2005 | 09:24 PM
n1mr0d's Avatar
Default Bent valves?
Ok so I was driving down the highway today with my B18C Sir II in third gear. I got to the rev limiter point (8500 I think) and went to shift to 4th but missed and shifted into 2nd. As I let the clutch out I noticed that I had done something wrong because of the car lerching forward and the engine did not decelerate. Within a tenth of a second that I let the clutch out I stepped in on it and looked down at the tach. It was coming down from 9k. After that, the car did not have the acceleration that it normally does and while I was coasting in neutral and I step on the gas it did not rev as quickly as it used to. So I got off at my exit which was a half mile away and drove home 2 more miles. I also noticed that at the stop light the engine would die if I was not revving it. When I tried to restart it, she was having difficulty turning over. So who can confirm that I bent the valves. I am going to pull the valve cover tomorrow to check timing and compression but I wanted to see if anyone else has a suggestion or has had the same problem and knows for sure what was needed to resolve it. Also it's not leaking any fluids so I don't think it's a head gasket issue.
Old May 23, 2005 | 03:13 AM
Takumi Fujiwara's Avatar
Default Re: Bent valves? (n1mr0d)
you probably bent valve(s). time to take the head off and take a look.
Old May 26, 2005 | 07:31 PM
PogKai's Avatar
no need to take the head. Check the compression.
Old May 26, 2005 | 07:53 PM
Suck my DX's Avatar
Default Re: (PogKai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PogKai &raquo;</TD></TR><TR><TD CLASS="quote">no need to take the head. Check the compression.</TD></TR></TABLE>
Old May 26, 2005 | 10:26 PM
Can't low compression numbers also mean blown rings?
Old May 26, 2005 | 10:49 PM
Suck my DX's Avatar
Default Re: (Takumi Fujiwara)
he didnt mention anything about smoke from his exhaust so i dont think its the rings..most likely bent valves
Old May 26, 2005 | 11:30 PM
Default Re: (AMPYR_one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMPYR_one &raquo;</TD></TR><TR><TD CLASS="quote">he didnt mention anything about smoke from his exhaust so i dont think its the rings..most likely bent valves</TD></TR></TABLE>
I didn't read the original post when I posted again... my bad.
Old May 27, 2005 | 08:54 AM
b18blackek's Avatar
u can also take the valvecover off, and look at screw on the top of the valves and compare them from the rest of the screws, should be centered and straight. and pull out all plugs and look into cylinders to see if there's any weird markings on the pistons
Old May 27, 2005 | 10:03 AM
mmuller's Avatar
Mad Scientist
Default Re: (B18BlackEK)
to find bent valves you can just check valve clearances...bent ones will be way off.
vtec@4000rpm
Feb 13, 2012 08:27 AM
type_r_jon
Jun 9, 2005 07:10 AM
finest_GSR
Jun 7, 2005 10:29 AM
RGoose18
May 21, 2004 09:29 AM
fredtoast
Apr 24, 2003 10:39 AM
